1985 450 E dozer engine oil pressure
Therealstilts
Post by Therealstilts » Fri Aug 03, 2018 10:00 am
Alright guys I have been stumped with this one. I have a 1985 450e deere dozer and am having trouble with the oil pressure. It is 30-40 psi cold and at a idle warm 5-10. Now I know everyone says shim the oil pressure relief valve so I took the front cover off and where the pressure regulator is suppose to be is a empty hole. So I ordered parts from deere and the hole is way to big for the parts. I need some help figuring this out. Everyone I ask that is knowledgeable seems to not know what I'm talking about I have pictures of the cover and plate behind the gears. Help please
Rincon
Re: 1985 450 E dozer engine oil pressure
Post by Rincon » Tue Aug 07, 2018 1:24 pm
Maybe your sender is bad. Mine was on my 450C. Barely had oil pressure. Now all good.
kilohertz
Post by kilohertz » Tue Sep 04, 2018 10:30 pm
Try threading a mechanical gauge in the sender hole to see what your oil pressure is...guessing it is 1/8" pipe thread. That will tell you if your sender or even gauge is bad. My water temp gauge got water inside and the readings went all wonky, ended up changing the gauge.
Cheers
1952 MC
1965 JD350 outside blade
1968 JD350 Drott 4 in 1
1965ish 710 green tractor
1978 212 garden tractor
2003 F525 circus mower
Post by Jim B » Wed Sep 05, 2018 5:18 am
Am I correct in saying your oil pressure gauge is a mechanical gauge? That is what my 450E has. It is not as likely there is a problem with a mechanical gauge it but check the tubing and you can always try a second gauge to see if it reads the same.
According to my Technical manual (Repair) the oil pressure regulating valve is located behind the oil cooler, not in the front cover. The parts catalog drawings would lead one to think it was in the front cover. You have to remove the oil cooler.
There are two technical manuals for the 450E you should have. The Operations and Test Manual # TM1330OP and the Repair Manual # TM1330RE.
Users browsing this forum: No registered users and 485 guests
