Hydraulic control valve on 450 C
Mountainman
Post by Mountainman » Wed Jun 13, 2018 7:11 pm
I have another question for all you experts. I have a 1979 450C dozer and trying to get used to it. According to the operator manual this 6way blade is supposed to have a float position if you push the lever all the way forward and stay there until you pull it back. Mine doesn't do this, is there an adjustment?
Mountainman
Re: Hydraulic control valve on 450 C
Post by Lavoy » Wed Jun 13, 2018 8:35 pm
Float lock may be damaged or removed by someone that doesn't want it.
hogbare
Post by hogbare » Thu Jun 14, 2018 7:07 am
How much slack do you have in the control lever? The 1 that I just but on my 450C would not go to float, rebuilt the control lever (new bushing,links,rollpins ). Wow I had float. Looked at my parts dozer, PO had notched the box so he could go to float. Amazing what a few bushings & pins can do. JD used to offer a kit for this NA now. Good luck.
Hogbare
