Lu47Dan is still around
Lu47Dan
Post by Lu47Dan » Sat May 05, 2018 7:47 am
I am still alive and working on things, I had trouble with my phone line that carries the internet. A lightening strike took out the cable and the fused it to the conduit, the phone company will plow in a new cable but only on the most direct line. So I am working on my old hoe to cure the leaks and I will install new conduit and cable, once that is fixed.
1956 420C with GSC blade
77 Ford
Re: Lu47Dan is still around
Post by 77 Ford » Thu May 17, 2018 7:08 am
Glad to hear! After owning a hoe for many years I'm convinced it has two modes of operation.
1) About to Leak
2) Leaking
I'm always changing hoses or rebuilding cylinders on that dumb thing.....
JD- 450C track loader
Serial #208336T
Post by Stan Disbrow » Thu May 17, 2018 7:30 am
That applies to everything!
(1) Failed
(2) Going to Fail
Ha!
psprague
Post by psprague » Fri May 18, 2018 9:18 am
No oil under it
No oil in it.
Lu47Dan
Post by Lu47Dan » Fri Sep 14, 2018 12:43 pm
Yes, that is very true. :roll:
We have had too much rain here to do much digging.
I bought a Samsung J7 Sky Pro smart phone, so I could get back online. So I will be around more.
Daniel
