Here is ready to put problem, I am putting engine back together. I have install crankshaft and installed the cam, BUT cam gear has 2 center punch marks, one is just below the dash mark of the cast numbers and there is 6 teeth between second center punched mark.. So which center punch mark do I use????
Keith
115 ci engine
115 ci engine
Keith
Re: 115 ci engine
Is that the key way on camshaft? I know it is marked at key way on crankshaft?
Keith
Re: 115 ci engine
Thanks Ralph, I pulled the snap ring on the camshaft, and the punch mark I used on the cam gear happened to be the correct one... I can't figure out why anyone would put a second punch mark on the cam gear. That probably why it wouldn't start when I first bought crawler.
Keith
Users browsing this forum: Google Adsense [Bot] and 234 guests
