2010 CRAWLER TRACKS 1963 model
royboy
Post by royboy » Mon Nov 27, 2017 12:21 pm
Need tracks for 2010 crawler s.no. 38522 1963... Pads are ok ... need the rails...
Thanks for any ideas...
royboy
Re: 2010 CRAWLER TRACKS 1963 model
Post by Tigerhaze » Tue Nov 28, 2017 2:09 pm
As you may or may not be aware, the individual track links (rails) for the "early 2010s (meaning prior to serial number 42,000) are the same as used for the 440 and 1010 crawlers- unfortunately those crawlers use fewer links than a 2010 so finding enough of them to create a complete 2010 track with the same rail height throughout may be tough. At one point Lavoy was making early 2010 pins and bushings sop you may still be in luck there if you can piece together what you need link-wise.
royboy
Post by royboy » Tue Nov 28, 2017 6:28 pm
thanks for the info... I have a friend helping ... I will see what all he needs...
Thanks again... royboy
Users browsing this forum: No registered users and 211 guests
