Model 831 loader on 440IC
pfish
Post by pfish » Fri Nov 17, 2017 9:03 am
I want to rebuild the four hydraulic cylinders on the loader, they don't leak but settle during operation. I have the spanner nut off of all four, the service manual says I need to tap the threaded end back slightly to remove the snap ring. I cannot get the end to move back into the cylinder, suspect it is corroded. I have hit it hard using a wood block and heavy hammer. Anyone have hints on getting the ends loose so I can pull the rams out?
Phil Fish, Middleton WI
Re: Model 831 loader on 440IC
Post by Lavoy » Fri Nov 17, 2017 10:08 am
Light heat, not enough to vaporize and cause the oil to explode.
pfish
Post by pfish » Mon Nov 20, 2017 8:32 am
Thank you very much!!
Users browsing this forum: Google Adsense [Bot] and 234 guests
