420 reverser
don racicot
420 reverser
Post by don racicot » Thu Sep 14, 2017 8:01 am
Looking for reverser parts the local Deere dealer says are obsolete. There is a bronze thrust washer that rides between the reverse drive gear and the direct drive gear that I need. JD part #M 3784 T. I think I can make one if anyone knows what the thickness of the washer is supposed to be. Also looking for the reverser control pivot that attaches to the control shaft and accepts the control lever. JD part #M 3786 T. Is there any source for Center frame bushings where the clutch/brake shafts and reverser shaft goes through the center frame housing? Thanks, Don
Re: 420 reverser
Post by Lavoy » Fri Sep 15, 2017 1:22 pm
I'm out of the office til Wednesday. Shoot me an email and I will check when I get back.
