hello again,
can anyone point me in the right direction.
1.
I need the front , crank shaft mount for the front mount hydraulic pump.
has the rubber bushings in it and bolts to the front pulley, (2-53)
shaft looks like 1 inch 6 spline.
maybe even a set of rubber replacement bushings that go in this thing.
new would be fantastic, used good to.
just got the loader back running, lots of fun. and work.
2. need the front hydraulic filter as well, this goes into the hydraulic tank.
big filter with a bunch of holes in it.
how about new seat foam and arm rests, complete with bolts and clips to put into my curved large heavy steel seat housing
(440icd)
3. also
need used 2-53 or new - john deer, oil pan, looks like its cast iron. for same tractor
that's just to start with.
boy.
hope someone can help.
thx
scott
parts needed 440icd
parts needed 440icd
Scott in wa.
whiteclipse16
Re: parts needed 440icd
Good luck finding the front pump mount. From reading on here a lot of those and their associated couplers get chewed up and are junk. Lavoy might have a used one on hand. There's usually a fellow on ebay that has a lot of 440 parts "Farmer John". His prices are pretty high though.
The filter you're talking about is an add on I think. 440's didn't come with hydraulic filters.
You're seat is a "deluxe seat" look for a cushion kit, there are numerous manufacturers out there reproducing them, Lavoy may stock them as well.
As far as the oil pan goes, good luck with that too. Mine was rusted through bad, I searched and searched and couldn't find a replacement. I ended up cutting the bottom out and welding an entire new bottom in it.
Ben
thanks Ben.
ya the filter is in the hydraulic tank, bolts in the tank, I've seen them on e-bay, but have not had any luck yet.
The front mount stuff I found, along with a couple used pumps.
I still need a seal kit for the original pump. its leaking a bit, to much. Hydreco
the seat I have now, was expensive, but looks good. feels good, old plywod seat will be gone soon
I bought another 2-53 its now apart, most parts will work, however its a old marine gen motor.
still beautiful, pan may interchange, will see.
so the quests continues.
I'm not ready to give up on this 440 yet. at some point I need to make sure I have all the parts to make it right.
then will need rollers chains, idlers and sprockets , just saying that makes me shudder.
I can imagine it would take a year or more for me to complete it. at least on that aspect.
Could go buy another loader, right now I don't think so.
s
s
Scott in wa.
