Bruser
Post
by Bruser » Thu Aug 24, 2017 3:44 pm
Sorry for the rookie question, but this is my first crawler! I have a 440 with a 831 loader. The tracks on the left side have become slack ( more than the right side). It has Hyd track adjust. My question: is there a special grease gun needed to "pump up" the adjuster.
I don't have the service manual but the operator manual says to use 140 gear oil. I don't thing my current grease gun will do that without making a real mess
Some help from the experts would be appreciated
Post
by mini kahuna » Thu Aug 24, 2017 5:08 pm
you need a low pressure grease gun, I use corn head grease for both my bottom rollers and the track adjuster.
you most likely still have the button head grease fittings for your adjuster and rollers, they look like little mushrooms....you can get the special fitting to screw onto a low pressure gun and you will be all set.
Lavoy might sell them or deere will have them.
you can use a regular grease gun for your adjuster but using regular pressure gun on bottom roller you can blow out the seal without even knowing it....using the low pressure gun gives you a better feel for amount if lube you have pumped into rollers
1010 loader
Bruser
Post
by Bruser » Thu Aug 24, 2017 7:39 pm
Thanks for the reply, I'll give the adjuster a shot with the current gun I have and search out the fittings for the L/P one.
Post
by Stan Disbrow » Fri Aug 25, 2017 4:07 pm
Here is a good place to start:
viewtopic.php?f=2&t=10405
gregjo1948
Post
by gregjo1948 » Sat Aug 26, 2017 5:15 am
I think you can get the grease gun fitting at NAPA.
- Site Admin
Post
by Lavoy » Sat Aug 26, 2017 12:18 pm
I stock ends and zerks.
Owner and moderator
www.jdcrawlers.com
Bruser
Post
by Bruser » Mon Sep 04, 2017 9:04 pm
Lavoy:
How do I go about getting an end for the "Mushroom" head fitting?
- Site Admin
Post
by Lavoy » Tue Sep 05, 2017 9:47 am
Give me a call 701-361-1006.
Owner and moderator
www.jdcrawlers.com
Users browsing this forum: No registered users and 171 guests
