440IC slipping
gregjo1948
440IC slipping
Post by gregjo1948 » Tue Aug 01, 2017 11:14 am
After working a while the main clutch or reverser is slipping. What's the best way to determine what's slipping?
Thanks, gregjo1948
original possum
Re: 440IC slipping
Post by original possum » Wed Aug 02, 2017 9:11 am
The main clutch will be "thin" if it is slipping. In other words, the slightest pressure past free travel will increase the slip. You need to pull the engine, regardless.
pcsaw
Re: 440IC slipping
Post by pcsaw » Wed Aug 02, 2017 7:53 pm
Make sure it isn't your steering clutches
