2010 loader leak
- vailvalley59
- 430 crawler
2010 loader leak
Does anyone have an aftermarket number for the seals in the tilt cylinder on this loader? Thanks much
2010 diesel loader, IH 886, Cat 1947 D4 dozer, IH 966, Ford 7000, IH 2500, IH 706 and other toys
fictional31m
- 420 crawler
Re: 2010 loader leak
any local hydraulic shop should be able to get you packing and seals likely cheaper than oem however quality could be different from oem depending on the shops source I always took the whole cylinder in to order that way your sure to get the right stuff if its not possible to take into the shop just the old packing/seals works most of the time
