350D Homemade PTO and 3 Point Hitch
CuttingEdge
Post by CuttingEdge » Tue Jun 13, 2017 5:36 am
I wish I could post pictures on here...
Atlas, they say necessity is the mother of invention, so I had to cobble something together for a PTO and 3 point hitch arrangement. I got a government grant to switch a corn field over to grass, and the more I do myself, the more money I can keep, and if you knew what my property taxes were, you would understand why I need all the cash I can. As with any government grant, if you take their money, you got to play by the rules and that meant spreading fertilizer, lime and seed too. A lot of fertilizer, lime and seed...
I found an old 3 point hitch fertilizer spreader (cone) for $100, but I was not about to buy bags of lime, nor shovel 30 tons of lime into it, so I had to install a pto and add a three point hitch onto my bulldozer so I can load the spreader with my Kubota tractor. A installed a short winch shaft, but that was still a 21 spline shaft, but an adapter got me down to 6 splines.
For the time being I just welded on brackets to hold the fertilizer spreader, but plan to add a hydraulically lifted set of arms as soon as this job is done. I am under a very tight time frame in order to get the seed in the ground.
All in all it should be a productive tractor then; a pto and a 3 point hitch can come in very handy at times.
Claus
Re: 350D Homemade PTO and 3 Point Hitch
Post by Claus » Thu Sep 28, 2017 7:28 am
Did you ever get photos of the 3 pt and PTO? Would be interesting to see.
