jd 2010 ignition ?
Spledger
jd 2010 ignition ?
Post by Spledger » Tue May 16, 2017 9:46 am
I am still working on my dad's old 2010, and i have realized i do not think he had the key for and wired the ignition to the on position possibly. i know he used to put a battery in it only when he wanted to use it then remove the battery when done. i know to start the 2010 i need to push the button , but how do i turn it off ??
shinnery
Re: jd 2010 ignition ?
Post by shinnery » Tue May 16, 2017 7:37 pm
This is a gas crawler I assume. Disconnect the battery cable. Or quickly remove the big wire from the coil, but you will still have current thru the points and coil primary.
Spledger
Post by Spledger » Tue May 16, 2017 7:49 pm
Thank you ! It is a diesel. Can I still disconnect the battery to get it to shut off ?
gregjo1948
Post by gregjo1948 » Wed May 17, 2017 3:20 am
I think you can. I believe it has to have electrical power to operate a fuel solenoid that allows fuel to the injector pump.
Post by Stan Disbrow » Wed May 17, 2017 5:34 am
IIRC, the original IPs used mechanical fuel shut-off, done by moving the lever all the way down.
Spledger
Post by Spledger » Wed May 17, 2017 7:06 am
Thank You All for the help!
I am probably a couple of months away from trying to crank this thing, but causing a little anxiety :D
Users browsing this forum: No registered users and 315 guests
