Hello all, I am picking up a job my late dad left behind. I have been working on replacing the steering clutches. As I was working I noticed I have no idea where he put all the bolts for the hydraulic tank, seat , etc.
I have the pets manual so I should be able to determine the size needed for all the bolts. Does anyone know if a place where I could order replacement bolts ?
2010 bolts
- gregjo1948
Any hardware store should have what you need. Tractor Supply has a good selection in my area.
- 440 iron popper
Personnaly I use Caterpillar bolts. All grade 8. I like the fact that they have this nice catalog where i can list all I need for a project. They are a bit expensive though. You can order them at your local cat dealer.
http://www.finning.com/content/dam/finn ... 5-2016.pdf
Page 409.
Page 409.
Users browsing this forum: Google [Bot] and 12 guests
