77 Ford
Post
by 77 Ford » Wed Apr 12, 2017 7:10 am
Where did you buy your motor from?
Ive not seen very many dozers with the backhoe hooks on the back. Thats neat.
Looks like youre going thru it right the first time.
JD- 450C track loader
Serial #208336T
ryan71407
- 420 crawler
Post
by ryan71407 » Wed Apr 12, 2017 7:57 am
This is the backhoe, it will be going out for Sandblasting also when dozer gets back.
ryan71407
- 420 crawler
Post
by ryan71407 » Wed Apr 12, 2017 8:01 am
I got the motor off of ebay from government liquidation, it is not a re-furb its a re-manufactured which means basically they change all parts out with OEM john deere parts. Motor Is brand new from starter to turbo. Its rated i think right at 100 hp. But way better fuel system and 24v starter and alternator should make it easier to start. Wanting to build a foresty Cab and put limb risers and muffler riser.
ryan71407
- 420 crawler
Post
by ryan71407 » Wed Apr 12, 2017 8:10 am
This is the foresty cab that I am making for it, should have a little better paint job also. Im using carboline carbomastic 15 for primer when they are done blasting it this week. Best paint you can buy.
Grease Gun
- 40C crawler
Post
by Grease Gun » Mon Apr 17, 2017 6:38 pm
Keep the updates coming....looking forward to watching the progress on this!
JD 550 Dozer
Cat 955L
cantbeatadeere
Post
by cantbeatadeere » Tue Apr 18, 2017 6:34 pm
MY HAT IS OFF TO YOU ------- Fantastic job
ryan71407
- 420 crawler
Post
by ryan71407 » Tue Apr 18, 2017 8:41 pm
Still looking for limb risers!!
Grease Gun
- 40C crawler
Post
by Grease Gun » Wed Apr 19, 2017 4:55 pm
So just to clarify, that is not your project dozer in the last picture, correct?
JD 550 Dozer
Cat 955L
Post
by Paul Buhler » Wed Apr 19, 2017 5:06 pm
Are you located in Louisiana (71407)? Just curious, there might be a source in VT, but shipping might be pricey. I'll ask around. Paul
ryan71407
- 420 crawler
Post
by ryan71407 » Thu Apr 20, 2017 7:47 am
No the last picture isn't mine! But I think my build will be as nice or nicer! And yes from lafayette la 70508.
Grease Gun
- 40C crawler
Post
by Grease Gun » Thu Apr 20, 2017 6:10 pm
I bet it will be!
While you have it down that far, are you going to check the transmission out? It would be a shame to do all that work and have to go back in.
JD 550 Dozer
Cat 955L
ryan71407
- 420 crawler
Post
by ryan71407 » Sat Apr 22, 2017 8:21 am
They went into the transmission when it was parked, I have a bill for $6400 for changing front trans case, pump, driveshaft, and setting all pressures. But like I said it sat for almost 10 years. I wonder what I need to look for in these trans??
Post
by Paul Buhler » Tue Apr 25, 2017 12:45 pm
Since no one else has chimed in, I'd think that if no water got in, the transmission should be fine. I'd check the accumulator though. Being high on the machine it may have some rust from condensation in it. It acts like a shock absorber during forward/reverse shifts and the adjustments can be finicky. Best wishes. Paul
ryan71407
- 420 crawler
Post
by ryan71407 » Mon Jul 10, 2017 10:24 am
So Im about to have it blasted, sandblaster wants to remove tracks to blast it correctly. First of all how do you remove the tracks? Second what should i look for or change while its apart. (seals) etc...
Users browsing this forum: Google [Bot], NevadaKid and 187 guests
