9300 Backhoe hydraulic relief valve
- 40C crawler
I have a dripping relief valve on my 9300 Backhoe. The valve is designed to dump fluid on the ground under over pressure conditions like if the return line is clogged. John Deere no longer makes a replacement. It screws into a 3/4" NPT plug. Any ideas for a replacement or retrofit?
relief valve
could be it needs new seals looks all the seals can be gotten at JD Parts.com
JIM
JIM
Re: relief valve
there is aftermarket relief valves available. You just have to watch the relief valve pressure settings when ordering a new one. There is various pressures available.
- 40C crawler
http://www.surpluscenter.com/Hydraulics ... ort+Relief
Or just do a google search for hydraulic relief valve
Users browsing this forum: No registered users and 42 guests
