JD 420 Blade cylinder
davea
Post by davea » Sun Oct 08, 2006 6:41 am
I have a 420 that the blade cylinder seals are shot.Are these available from any aftermarket sources? It is the blade with the frame inside the tracks.
Post by JD440ICD2006 » Sun Oct 08, 2006 7:42 am
Your local JD Industrial Dealer should have the repack kit if they are original JD cylinders. Get a casting number and contact them.
My local JD ID wanted $75/hour and estimated 3-4 hours to repack one cylinder. I had never been in to one, did it in about 1 1/2 hours with minimum tools and shop equipment. Not sure what all they do in those 3-4 hours, but my cylinder now is dry as a bone, no leaks.
country53
JD 420 Blade Cyl
Post by country53 » Sun Oct 08, 2006 9:38 am
I rebuilt mine including replacing the rods and I got all new parts at a local hydraulics shop. The piston cups were upgraded to modern material and rod seals and barrell seals were upgraded too and I just got a peice of chromed rod material and made new rods.
Users browsing this forum: No registered users and 260 guests
