440 looking good
barnie
440 looking good
Post by barnie » Sun Oct 08, 2006 12:29 am
that 440 of yours looks real good lavoy, must of took alot of time to make it so nice.i was just woundering if your machine had the hydralic pump on the end of the crank or not ?mine is on the crank and it sure has lots of power ,i can kill the motor right down if i try. maybe my engine is weak,whats the compression on this engine do you know?
Post by Lavoy » Sun Oct 08, 2006 10:43 am
Not sure which 440 you mean?
Seems to me a good engine will be about 120lbs, late 440 will be higher.
