JD 440 ICD fuel shut off
- JD440ICD2006
Would anyone that has an original fuel shut off on their GM 2-53 diesel please post pictures of what it looks like? My old parts book does not show the parts.
Mine was taken off and they just had the throttle set to shut it down.
I like my throttle set to around 600 RPM at idle, so I want to build the parts to make it shut down at the governor. It looks simple, I just need a shot or two to figure it out. Mine has the cast piece that the rotating piece goes in, and the clamp that holds that end of the cable that runs to the dash.
Any help would be appreciated.
- emichaelhaynes
- 430 crawler
just made one of those...
made one from scratch. don't like it. it works good but i don't like it. gonna make another one soon. i'll take a pic tomorrow. when i do phase two i'll make an extra one if you're interested.
michael
michael
- JD440ICD2006
Michael,
Yes, I am very interested. Please send those PICS and if you can make two of "phase two", I could use one. That would save me from "reinventing the wheel", so to speak.
yellowcrawler
- 420 crawler
Another makes 3
Michael,
I have a 440 ICD also, would appreciate pics, and am definitely interested if you could make an additional "phase two".
Thanks,
Walter
Thanks,
Walter
- emichaelhaynes
- 430 crawler
phase two
no problem
michael
michael
- emichaelhaynes
- 430 crawler
phase 33 1/3
if you were expecting carved from a solid block of chrome-molly and then triple plated sorry to disappoint you. well somewhat... that's phase three.
this is phase one:
this is phase one point seven five:
same piece. realized i couldn't weld the little hex nut to the plate with a stick 'bout two seconds ater i tried. sold the mig welder back in '97 when we moved on the boat. been on dry land now for little over a year... not quite up to snuff yet... the victor 100 is down in el lay in storage with my bridgeport... bought a new gas setup... ain't got here yet...
if you two guys still wanna copy it'll cost you postage.
michael
this is phase one:
michael
yellowcrawler
- 420 crawler
- JD440ICD2006
Michael,
I will gladly pay the postage for one. Send me a Private Message and we can get all the info.
Thanks!
Thanks!
Michael,
Is fuel shutoff not available from JD dealer, and is that why you built your own? Did you try repairing yours before manufacturing a replacement? The fuel shutoff of the 2 cyl diesel in my 440IC doesn't work right and needs to be replaced or repaired, what do you charge for "Michael Manufacturing" replacement, thanks.
Floyd
Floyd
- emichaelhaynes
- 430 crawler
there were only ~11,000 2-53s used in the 435 and 440 in '59 and '60. the gas engine was the same more or less as used in the 420 and 430. don't have a clue as to how many gas motors were made but i 'spect it was many times the number of diesels.
a number of parts made or used by deere for the 2-53 just for this application. you're not gonna find them anywhere anymore. go online at johndeere.com and see for yourself.
my shutoff was missing as was i suspect more than few others are/were. haven't figured out what to charge. doesn't take long to make one. pm me with your address and i'll make sure you get one.
michael
michael
Users browsing this forum: No registered users and 145 guests
