Oil in rollers
Oil in rollers
Post by JD440ICD2006 » Sun Oct 01, 2006 7:39 am
I have bottom rollers with the center plug in them. I am told that they take oil, not grease. I opened one and it is indeed oil. Any idea what weight oil goes in these?
JD dealer said 30 WT ND, another source said same as tranny and finals.
I wish there was one correct answer to these lube questions. LOL
Post by Lavoy » Sun Oct 01, 2006 2:37 pm
My inclination would be 90 wt, but you are talking a later model or aftermarket roller, so I am not sure.
Post by JD440ICD2006 » Sun Oct 01, 2006 3:10 pm
Thanks for the reply. I agree, seems like 30 would just be too light. I do not have a mfg or model number for these rollers, they replaced some of the originals.
drrick
Post by drrick » Tue Oct 03, 2006 3:08 pm
My 450 - c has those type rollers and it is indeed a 30 wt oil you should use. If yuo use a heavier oil in them when they are in good shape they will not lube properly and will be damaged. Even a worn one with bad seals won't lube well with 90 weight. This is per the JD service manuel I have
The way to fill is to place a grease fitting in the center hole and remove the other plug. Fill with pressure gun Gently until the oil flows out the other hole. Replace plug, remove grease fitting and immediately replace other plug. BTW the manuel says loctite is to be used on the pipe plugs.
rick
440 icd loader, 450-c dozer, 410 backhoe, 72 IH dump, wife and 4 kids(grown almost)
Dozerdave
oil for rollers
Post by Dozerdave » Thu Oct 19, 2006 3:00 pm
I have been using corn head grease for years without a problem. Close in viscosity doesn"t leak out. Dozer Dave
Users browsing this forum: No registered users and 37 guests
