jgbanshee
- 420 crawler
Post
by jgbanshee » Sat Sep 30, 2006 6:41 am
I have 1966 450 dozer with the HLR and when I put it in R it won't move backward. I tried going through the speeds on the left hand side and I noticed them grinding into each gear. The clutch seems like it isnt even there. When I press the clutch in and leave it out, it doesnt seem to grab anything.
digitup
Post
by digitup » Sun Oct 01, 2006 7:54 pm
If you have forward gears only then your reverse clutch is gone.Digitup.
jgbanshee
- 420 crawler
Post
by jgbanshee » Tue Oct 03, 2006 5:48 pm
I got the machine to move forward today. I put it in L and 1 and it drives forward. It does not turn left or right or move in reverse. I tried every combination of ranges and speeds and still could not turn either direction or reverse. Is the problem still the reverse clutch?
digitup
Post
by digitup » Thu Oct 05, 2006 7:38 pm
I would say it is a multitude of problems 1 steering clutches 2 power shift clutches Both need to be looked into.Digitup.
jgbanshee
- 420 crawler
Post
by jgbanshee » Wed Oct 11, 2006 5:42 pm
How do I go about this?
digitup
Post
by digitup » Fri Oct 13, 2006 7:38 am
1st step is a look into the clutch housing and see what condition the clutch is in 2nd step is the power shift housing A service manual and parts manual for your machine would be good to have before starting this task.Digitup.
jgbanshee
- 420 crawler
Post
by jgbanshee » Fri Oct 27, 2006 4:16 pm
My JD straight 450 crawler will not steer either direction. I bought a tech manual for it and started studying it. I pulled the hood off today and found that the power steering reservoir was completely empty. So, I added fluid and the steering levers (when pulled back) jerk or bounce rapidly and it still will not turn. The transmission fluid is full too. Of the H-L-R transmission, the R does not work either.
Users browsing this forum: No registered users and 37 guests
