John Deere 440IC 3 point draw bar support
DukeofDeere
Post by DukeofDeere » Sat Dec 03, 2016 7:49 pm
How do I remove the 3 point drawbar support?
Bushings in each hole that the bolt goes through.
Thanks,
Duke[/quote]
JD430C
Post by JD430C » Sun Dec 04, 2016 1:07 pm
Most of the ones I have worked on had treads on the bushings so you could tread a bolt into them to remove them. I never had any luck getting them out, ended up unbolting removing a final drive to get that drawbar support off.
Andrew
original possum
Post by original possum » Sun Dec 04, 2016 1:26 pm
Chase the threads first. Then put in a bolt through a 3/4" drive socket and pray a lot as you tighten it.
DukeofDeere
Post by DukeofDeere » Mon Dec 05, 2016 5:51 pm
Thanks for the input!
Duke
