Stianless steel hydraulic line fitting, 831 loader
440icd
Post by 440icd » Wed Sep 27, 2006 9:53 am
440icd late model with 831 loader
Hi Lavoy here is my problem
On the front loader spool, that tilts the bucket up and down, there is a stainless steel short section that threads into the spool. The lower end of it has two threaded fittings that the hydraulic lines hook into.
I blew the top nut that the threads into the spool.
The top nut that goes into the spool is o-ringed to the spool, the bottom of the nut is held on by a small round clip that sits in the groove in the nut.
The groove is worn out. Thus... she blew off.
I may try and get the local Parker Hydraulic shop to set me up with something that will work. But.
Do you have this whole piece or just the nut???
Scott in wa.
Post by Lavoy » Wed Sep 27, 2006 9:55 am
No, don't have that one, sorry.
lavoy
440icd
fitting
Post by 440icd » Wed Sep 27, 2006 9:58 am
what is that type of fitting called?
thanks
Scott in wa.
Post by Lavoy » Wed Sep 27, 2006 10:18 am
Sounds like some sort of tee fitting.
Users browsing this forum: No registered users and 306 guests
