1010 hydraulic valve leak
norski786
Post by norski786 » Tue Nov 15, 2016 6:42 pm
I purchased a 1010 crawler.It has hydraulic oil leaking out the top of the spool in the control valve.Is there a fix for this or am I looking at replacing the control valve?
it does not have to be perfect as long as it's exact!
Mikeym70
Repair
Post by Mikeym70 » Tue Nov 15, 2016 6:59 pm
The spool can be pulled out, but condition of your spool will determine if a new cup seal will fix the issue. I had same issue on mine and put new cups in it. It leaks less, that's all I can say.
1010 gas crawler 6 way blade. New to me 3/2015.
Post by jtrichard » Tue Nov 15, 2016 7:50 pm
Lavoy may have them part# should be T10638 takes one top and one bottom for each spool
Users browsing this forum: No registered users and 316 guests
