Late model 440, 253 Detroit
I have been looking and found a few oil filters for this 2-53.
It looks like there were several toy filter used???
I pulled mine, it looks like a sock typ filter, is this correct, or should it be that NAPA 1006 this one looks like its a paper type.
Can't seem to find a part number for the sock typ.
440 icd oil filter, sock type?? or paper type?
Scott in wa.
- JD440ICD2006
I just changed the oil in my 2-53 recently. I used a NAPA 1100 replacement filter. The one I pulled out was a WIX 51100. Unless you know something bad about these, it appeared to be working and fit fine. It looks similar to the NAPA 1100 with a little handle at the top.
Thanks for the new alternate on the fuel filter from NAPA. Detroit Diesel still sells the original 5196048 too.
- JD440ICD2006
The fuel filter that I am going to use is paper. It is the original one from Detroit Diesel.
The oil filter is a metal container with holes in it and a little handle on the top to help pull it out of the canister. Both the NAPA and the WIX are made basically the same.
Both the fuel and the oil filter from NAPA are paper filters in a metal canister. I think in a previous post someone actually went to the website of the original fuel filter housing manufacturer and cross-referenced the fuel filter so I think it is correct. It certainly fit well when I installed it.
Users browsing this forum: No registered users and 272 guests
