Just bought a '56 420c, there are a few things that it needs done to it. but the first thing I'm looking at is rebuilding the valve that raises the blade. The valve sticks at times when trying to raise the blade. A tug on the handle has so far freed it up. The valve also leaks much more that I would like. Has any one "been there, done that"? I would much appreciate any comments or help.javascript:emoticon('
rebuild of hyd. valve?
New here, thank you for the sight, very much appreciated!javascript:emoticon(':D')
still going green
Sticking might be in the linkage. If it is the factory valve, I have done many of them. Not rocket science, just kind of a pain.
Laovy
Laovy
No kits, all individual parts. Whining can be improper fluid, or maybe linkage out of adjustment, but nothing that a rebuild will cure. Usually the only whine is when the bypass opens, and that means you have to be at the end of ram travel, or one of the piston in the valve is out of time which is a linkage adjustment issue.
Look at the pivot bushing and bolt in the lever itself as well. Make sure both piston move at exactly the same time. One goes in, one goes out, and any thing other than at the same time will restrict flow.
Users browsing this forum: No registered users and 213 guests
