MC Battery??
jim1932
MC Battery??
Post by jim1932 » Wed Sep 14, 2016 2:13 pm
Going try to get my Dad's MC running this weekend. It ran good but has been parked several years (Massachusetts). I assume the battery is shot. As I live in Maryland, the only thing I have to go by are pictures. The battery in it is a 58-2 650amp. That looks to be a 12 volt. How likely to that to be correct?
Just trying to figure if I need to buy a 6 volt to go up with (can take a 12 volt out of his truck). No I can't just ask him.
Post by Stan Disbrow » Wed Sep 14, 2016 2:34 pm
They were all Group 1 six volt. But....many have been changed to 12 volt....often poorly.
So....there is no way to say what you have. 50/50 chance of it being either.
One thing I must point out: Be very careful as these machines stick the battery under the gas tank. They are top post, so it is very easy to short the battery to the gas tank. Which tends to burn a hole in the tank so you get to have both a battery and a gas tank fire at the same time.
Post by jtrichard » Wed Sep 14, 2016 7:43 pm
58-2 is a 12 volt i would say you should take a new 58-2 with you
jim1932
MC Parts?
Post by jim1932 » Fri Sep 30, 2016 9:34 am
Need a Fuel line, plug wires and plugs. I assume these are mostly generic. The "Fuel line " on it was an Air brake Line.....
shinnery
Post by shinnery » Fri Sep 30, 2016 7:49 pm
For spark plug wires you need to use wire wires not radio suppression wires. Get a better spark to the plugs this way.
Users browsing this forum: No registered users and 248 guests
