Gearmatic 8A Winch Bearings
JDCrawlerdog3
Post by JDCrawlerdog3 » Mon Aug 08, 2016 6:14 pm
Finally got the winch torn apart without burning the barn down or loosing any fingers - quite a job. Does anyone have a list of replacement bearings? The parts list only identifies the ring and pinion bearings. I need to replace all the bearings on the shaft. Original bearings are too corroded to read any part numbers. Any help would be appreciated.
Thanks!
Andrew
notmeu
Re: Gearmatic 8A Winch Bearings
Post by notmeu » Tue Aug 09, 2016 12:45 pm
Andrew, I just completely rebuilt my 8a including the bearings/seals in the mounting plate and the controller last winter. I made a list of all of the new bearings, seals, and places I got work done on the winch. I can't seem to find it at the moment, I know I sent a email to paul buhler with all of this info. Maybe he can send it to you if I cannot find it. I know I got most of the bearings on eBay as new old stock items and I saved a ton of money. The bearings are easily cross referenced online using the old numbers. Also Lavoy can probably get them for you!
Post by Lavoy » Tue Aug 09, 2016 2:49 pm
I don't have the part numbers I don't think, but they should not be that difficult to find by size.
notmeu
Post by notmeu » Tue Aug 09, 2016 3:46 pm
Andrew, I sent you a personal message with all of the bearing numbers you needed.
JDCrawlerdog3
Post by JDCrawlerdog3 » Tue Aug 09, 2016 6:45 pm
Notmeu,
Got your PM and the info. Great help, thanks!
Andrew
Users browsing this forum: No registered users and 238 guests
