Track adjuster problem
jcastigl
Post by jcastigl » Mon Aug 01, 2016 7:36 pm
Well I was washing the mc today took me 4 hours to clean all the fragmitas and mud out from the undercarriage not a happy camper. Well straight to the point I noticed that my left inside track adjuster is coming off of its guide. It's some what on the flat part twards the front of the tractor but the back of it is off of the guide and above it about an inch the front of it where the tensioning bolt is pointing in twards the idler wheel.. I don't know if the idler axle is bent of it just simply came off of its track. It doesn't move when the machine is moving back to the barn I'm terrified my new baby is broken already. PLEASE HELP ME anything comments are greatly appreciated
PS don't tell the women I have another baby in the barn now she may just kill me hahaha
Nothing like an old tractor
jcastigl
Post by jcastigl » Mon Aug 01, 2016 7:52 pm
The part that is coming off is part 30B If I'm looking at the parts book correctly
http://s1249.photobucket.com/user/Jcast ... sort=1&o=2[/img]
Imagehttp://s1249.photobucket.com/user/Jcast ... sort=1&o=0
shugy368
guide
Post by shugy368 » Tue Aug 02, 2016 7:51 pm
Can't see your pics for some reason, but I think you're talking about the Idler assembly and it's rear guide that slides on the carriage assembly,with the adjuster bolt and nuts attached to the Idler. Is the rear rock/branch/any foreign object preventer still in place on the rear of the Idler assembly?
jcastigl
Post by jcastigl » Tue Aug 02, 2016 8:13 pm
Everything that's on the undercarriage seems to be in place I'll take pictures tomorrow heading out to a tractor show this weekend taking my cub and a couple others I have. So I might not get the pictures up until Sunday night I'll try to get them up earlier.[/code]
jcastigl
Post by jcastigl » Tue Aug 02, 2016 8:16 pm
As far as I know this tractor doesn't have a rock gaurd because it uses the mc 1000 tool carrier that has the hydrolic cylinders on top of the roller housing. But yes
that is what I'm talking about.
Post by Lavoy » Wed Aug 03, 2016 8:05 am
Shaft is most likely stripped. Split the track and pull the idler and brackets off and you will know in short order. Do not keep running it this way, the dollar meter will be clicking if you do.
shugy368
track adjuster
Post by shugy368 » Wed Aug 03, 2016 4:08 pm
After looking up the MC in my service manual, I see the track tension adjuster is completely different than my 420-C's so all my advice can be tossed out the window with the baby and bathwater :lol: I think Lavoy is on the right track, after all is said and done you'll know her that much better. You might learn a few new words too, I know I did replacing my idler shaft last mo :roll: Good luck
jcastigl
Post by jcastigl » Wed Aug 03, 2016 5:01 pm
I'm going to give it a shot when I get back from the tractor show be ready for loads of questions. Lavoy do you have a number I can call you for tech support on the fly?
Post by Lavoy » Fri Aug 05, 2016 7:59 am
701-361-1006
