Please help! Bad fuel injectors JD350b
Jb800
Post by Jb800 » Sun May 15, 2016 8:26 am
I need some help and not sure what to do. I have an early JD 350B dozer that hasn't ran in a while. I tried to get it started but its been sitting with diesel in it and it seems the fuel clogged everything. I put new filter and a brand new injection pump. I have fuel going to the injectors but nothing coming out of the return line. I believe the injectors are stuck or no good. I would replace them but the problem is they are frozen in there and I can remove them. Not sure what to do. Any suggestions? Anything I can do to clean these injectors out while they are in the engine? Thanks
Re: Please help! Bad fuel injectors JD350b
Post by Tigerhaze » Mon May 16, 2016 9:26 am
Jb800 wrote: I have fuel going to the injectors but nothing coming out of the return line. I believe the injectors are stuck or no good.? Thanks
The return line for indirect injection systems comes from the injection pump, not the injectors. The return line should always have flow when running because it bypasses the excess fuel coming in from the pump inlet not used by the injectors.
Since you got a new pump you can probably cross that off the list (although for others there can be blockage in the pump). Check the return line itself to the fuel tank- sometimes the line will be plugged at the fuel tank itself if there are any portions of the fuel return line that are rubber, they can sometimes degrade from the inside and collapse. Hopefully that solves your issue.
Users browsing this forum: No registered users and 275 guests
