early 40C tracks vs Late 40C
DukeofDeere
Post by DukeofDeere » Mon Apr 18, 2016 5:53 am
How different are the early tracks from later style?
Thanks,
Duke
Post by Lavoy » Mon Apr 18, 2016 10:21 am
None.
DukeofDeere
Post by DukeofDeere » Mon Apr 18, 2016 10:31 am
Is it that the MC that is different?
40-440 all the same?
Thanks,
Duke
Post by Lavoy » Mon Apr 18, 2016 3:27 pm
No, BO, MC and 40 links are the same. 420, 430, 440 links are the same. 1010, 2010 under 42,000 are the same.
BO and MC pads til the 19,000 serial number range are the same. Very late MC pads, 40, 420, 430, and 440 pads are the same. 1010, 2010, 350 pads are the same.
I think this is what you are asking?
DukeofDeere
Post by DukeofDeere » Mon Apr 18, 2016 6:39 pm
I was of the understanding that there was a split in the 40 line on tracks.
Duke
Post by Lavoy » Mon Apr 18, 2016 7:57 pm
Nope, no change on the 40's, same from beginning to end.
DukeofDeere
Post by DukeofDeere » Mon Apr 18, 2016 8:10 pm
Thank you Lavoy!
Duke
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Tue Apr 19, 2016 5:49 am
The 5 role was introduced on the later 40's
nothing crawles like a deere
Post by Stan Disbrow » Tue Apr 19, 2016 6:16 am
Also, when working on these old machines, sometimes you find someone has put newer rails on. Like finding 4-bolt pads on a 440 for example. Or, even older rails on newer machines. So, then they don't match up. Easy to get all confused. ;)
If I were to rerail my 420, I would go to JD350 rails with rim sprockets welded onto cut down 420 sprockets. That would then confuse whomever wound up with it down the road.
mapaduke@yahoo.com
Post by mapaduke@yahoo.com » Tue Apr 19, 2016 6:30 am
Your right Stan, people had to do what ever they could do to get this running again and some times I appreciate the inginuity but for the most important I like to have mine as close to original as possible although I do have four bolt pads on my 430. lol
Users browsing this forum: No registered users and 356 guests
