JD450 Steering clutch. Need help
Jarret440
Post by Jarret440 » Fri Apr 15, 2016 8:54 pm
Hey guys new to this forum I have a 1980 John Deere JD 450 B it does not turn left at all I need to replace the steering clutches any tips or tricks to doing this job? I know I need to remove the blade and the roll cage but I do not know how to split the track please help thanks guys
Post by jtrichard » Fri Apr 15, 2016 10:06 pm
np205
450 steering clutches
Post by np205 » Mon Apr 18, 2016 9:47 am
Also have my 450B up on the operating table for steering clutches.
Have a digger derrick truck, that helps a lot with lifting off tank/seat assembly, moving tracks around, etc.
Set tractor on blocks of oak chain-sawed out of a recent downed tree.
Had to use a block of wood and Enerpac to get sprockets off.
Whacking with a sledge from opposite side while some pressure was applied to sprocket with Enerpac and they came off easy enough.
Biggest problem I have had so far is annoying cotter pins frozen in linkage. Clipped them off flush and drilled out after removal.
Actuator arms on horizontal shaft had to be gently heated to get them moving toward outside. Pinch fit with woodruff key on two of the parts.
Have to watch for those.
Bungs for pinion set screw and brake shaft were frozen, more gentle heating and they came out.
My tracks needed replacing too, so they almost fell of when the tensioner was compressed.
Definitely not a one evening job, at least for me.
JD 450B Loader/93 hoe - JD 410 TLB - IH 424, IH 354, Case IH 685
Users browsing this forum: No registered users and 89 guests
