2010 engine clutch disc
MADJACK
- 430 crawler
looking for a good source I called my local dealer and they said it's an obsolete part. there was one listed on Yesterday's Tractors but it was for a gas model I have a diesel with an HLR transmission. also what should I expect to pay?the dealer was able to get me an after-market one for it was over $200 I thought that sounded High.
IF Lavoy does not have a source for one theses guys should be able to reline yours http://www.clutchmasters.com/contact-us/ ...What is wrong with yours? with HLR on a 2010 you should never have to replace clutch unless maybe it got oil soaked
Should be readily available rebuit or new. If you know the part number, e-mail it to me and I will check. Can't find my 2010 parts book right now.
MADJACK
- 430 crawler
MADJACK
- 430 crawler
Ok, thanks for the information I have an operator's manual as well as the service manual I only drove it a little bit before I tore the engine out of it. actually the only thing I did with it was moving A lathe
I plan on reading up on it before I start actually using it I'm new to this stuff.
thanks for all the info and replies.
