I have a JD 310A and while tearing into it to replace the hydraulic pressure control valve o-rings I discovered 4 grease fittings on top of the rear axle. One by the outboard bearings and one on either side of the transmission. Any idea what kind of grease and how much I need to put in there?
JT
JD 310A
- cowboy4996
- 430 crawler
The outboard fittings are for the outer bearing...All they require are a couple of pumps of grease ONCE a year. Just use a good quality grease. Overgreasing can blow the seal out. I'm not sure about the inner fittings. I just looked at an ag tractor and didn't see anything but those outer fittings. It was a bigger tractor tho.
JD MC JD H JD L JD hit and miss engines
JWB Contracting
Grease Fittings
The grease fittings near the bottom of the axle case and pointing forward will most likely be used for bleeding the brakes. This is what I have seen on a 410, so a 310 is most likely the same.
Jason Benesch
John Deere 400G With Winch
John Deere 2010 Crawler Dozer
Maybe if you grease them, they won't be seized up whenever you need to bleed the brakes!
