450c Final Drive parts
DBaker98
Post by DBaker98 » Sat Apr 02, 2016 7:28 am
Hello All, my '78 450c loader right side final drive has failed. Removed the track and found that the outer drive bearing was destroyed. Removed final drive assembly to find teeth from bull gear and pinion shaft laying in the bottom of final drive oil pan. The loose teeth had broken 3 holes in the casting. Anyone have any leads on a 25 spline bull gear, final drive oil pan and clutch pinion shaft. The sprocket shaft is good.
Thanks for any leads.
Post by Lavoy » Sat Apr 02, 2016 9:27 am
I might have availability of some or all new. Can't check til next week, but send me an e-mail at postmaster@jdcrawlers.com and I can check for you.
Users browsing this forum: No registered users and 34 guests
