I have a JD 350 C. I went to adjust the valves and there are NO set screws with lock nuts on the rocker arms above the push rods. There is a nut on the push rod below the rocker arm. Looking down into the hole in the rocker arm above the push rod it looks like a tube is threaded into the rocker arm but I see no way to adjust that. WHAT DO I HAVE???? Can and how do I adjust the valves? HELP PLEASE
Thank you
donnaldp46[/img]
350 C valve adjustment
I know this is late but the nut is what you turn to adjust the valves. They are fitted in the rocker arm with a very tight fit. So it takes considerable force to turn these nuts. Sorry again for not seeing this post earlier.
donnaldp46
- 40C crawler
