JD350 Lift Cylinder
jthornton
JD350 Lift Cylinder
Post by jthornton » Tue Mar 08, 2016 5:59 pm
Does anyone know where I can get a lift cylinder for a JD 350 6 way blade? One of mine the packing nut just spins and won't come off or tighten up.
JT
Post by jtrichard » Tue Mar 08, 2016 8:15 pm
Is just the nut spinning OR the whole gland/slug? ..... The packing/slug/gland is NOT screwed in the tube there is a thin nut that has the notches in it it pulls the gland out against a snap ring if you pull the blade all the way up and hold it while some one ties to tighten the nut OR all the way down so that the piston tries to push the gland out you should be able to tighten OR loosen the nut so you can clean the threads up hope this helps Richard
jthornton
Post by jthornton » Wed Mar 09, 2016 8:15 am
Richard, thanks for the info. I was just assuming it was like my JD 310A. I went out and looked close at both of them and I see what your talking about.
JT
