1960 jd 440 icd reverser fluid capacity
frozendozer
Post by frozendozer » Wed Mar 02, 2016 9:56 pm
Hello All
just installed a new reverser in my 1960 JD 440 icd and was looking to put the ATF in, how ever when I look at my repair manual, there is no information on how much to put in.
Please help
Post by Stan Disbrow » Thu Mar 03, 2016 6:11 am
I don't rightly know. At least I never measured the amount. The instructions were simple:
Pull the RH bung, which is lower. Pour oil into the LH bung (which is easier to use a funnel with) until it flows out the RH one. Put bungs back. ;)
Use hydraulic fluid, like JD Hygard or any brand of JD 303 equivalent from any tractor supply store. I am not sure what all those extra additives in ATF might do that is unwanted. ATF today is nothing like what ATF was in 1959. Hydraulic fluid is. ATF might make the clutches slip.
Edit: I changed it from 'no one knows' because, of course, Lavoy knows! :P
Post by Lavoy » Thu Mar 03, 2016 8:20 am
About a gallon. I always buy a gallon jug of HyGard or equivalent, and that usually does it. It might be 5 quarts, I don't have my service manual to check it handy.
Post by Stan Disbrow » Thu Mar 03, 2016 8:49 am
I buy it in 5 gal pails, so never had a good reference. Same with the gear oil. Pour or pump until full. ;)
If they give me a 'full' hole for it to come out of, I don't need a measured amount. :P
Users browsing this forum: No registered users and 357 guests
