boom cylinder
butchb
boom cylinder
Post by butchb » Mon Feb 01, 2016 6:21 am
john deere 350 loader hydraulic boom cylinder, how to remove from machine for repair what is needed to pull back pin?
1967 jd 350
egeor
Post by egeor » Mon Feb 01, 2016 7:48 am
were the pin goes through the cylinder towards the outside of machine you should find a bolt
If you are rebuilding yourself my 350c cylinder had a set screw and locktite holding the gland nut or rod guide.You may have to put heat on it .
68 350 loader
79 350c loader
88 case 580k 4x4
89 ford 2120 4x4
