Hydraulic pump
lcfrace
Hydraulic pump
Post by lcfrace » Sat Jan 30, 2016 7:17 pm
My hydraulic pump for my 1010 is leaking out the back seal. Is there a rebuild kit, or can I buy a rebuilt pump. Thanks for any help.
1010 JD Crawler, 310 Case dozer, 977 Case track loader, RayGo roller
Post by jtrichard » Sat Jan 30, 2016 8:04 pm
IF it is a Cessna pump then it should be a NAPA ....NOS 8648 or a CR8648 .....7/8" id.... OR if it is a 1" shaft then it should be a CR 9843 or SKF 9843
lcfrace
Post by lcfrace » Sun Jan 31, 2016 9:08 am
jtrichard wrote:IF it is a Cessna pump then it should be a NAPA ....NOS 8648 or a CR8648 .....7/8" id.... OR if it is a 1" shaft then it should be a CR 9843 or SKF 9843
t
Post by jtrichard » Sun Jan 31, 2016 3:51 pm
OOPS those are the shaft seal numbers :) :)
lcfrace
Hydraulic pump
Post by lcfrace » Sun Jan 31, 2016 6:18 pm
Do you have the number for the back seal to the pump. It is a Cessna. Thanks
Users browsing this forum: No registered users and 169 guests
