Will a bucket interchange between a 350c and a 450c
B Town
Post by B Town » Sun Jan 10, 2016 3:17 pm
I have found a 4 in 1 bucket for a 350C and wondered if it would fit my 450C. It would be simple to measure but i dont have a 350 and the bucket is some distance away. Thank you, Bruce
MarkW
Post by MarkW » Mon Jan 11, 2016 5:52 pm
I have no idea, I'm certain someone will eventually say yes or no but in the meantime I have mine parked outside the back door (dragging firewood trees) and for the upper mount on the loader bucket there are the 2 plates the trunnion pins fit into, on mine the inner ones are 26" apart and the outer ones are 34" apart. If your 450 can accommodate that spacing let me know and I'll get the other dimensions for you.
MarkW
Post by MarkW » Mon Jan 11, 2016 5:56 pm
Also on my 350C the bucket is 65" wide.
pondhogvt
350 vs 450 bucket
Post by pondhogvt » Mon Jan 11, 2016 7:46 pm
Dear sir,, I measured a 350 parts loader in my yard...
On the backside of the bucket,,, the brackets that hold the pins for the loader arms...
outside of bracket to outside of bracket on opposite side is 33"s
with a 3 3/8"s space for loader arm to slide into..
with 1 1/2" diameter pin...hope that helps.. Mark
same spacing top and bottom conection
LeonardL
Post by LeonardL » Mon Jan 11, 2016 10:25 pm
No they won't interchange.
