BearRocks
Post
by BearRocks » Fri Dec 25, 2015 11:40 am
After running my 1010 for 20-30 minutes I lose the down pressure on the blade. Still can lift the blade. After sitting for a day it again works for 20-30 minutes. Any suggestions as to what the problem is and will it hurt to keep running it like this?
Thanks for any help.
DukeofDeere
Post
by DukeofDeere » Fri Dec 25, 2015 12:20 pm
Is the oil level up?
Oil clean?
Check linkage on the lever and valve.
Duke
Post
by jtrichard » Fri Dec 25, 2015 2:40 pm
Could be the cup/piston seals on the lift cylinders
original possum
Post
by original possum » Fri Dec 25, 2015 6:04 pm
Cold oil is thicker and develops more pressure in a worn out pump. Check the pressure and see if it drops as the oil warms.
Steven Walters
Post
by Steven Walters » Fri Dec 25, 2015 6:54 pm
Sounds like there is an issue with spool. Flow meter and gauge should be able to find problem.
BearRocks
Post
by BearRocks » Sat Dec 26, 2015 5:18 am
Thanks for all the suggestions. This time of year's not the best time to be spending money on a dozer
so I may just keep "babying" it along.
Users browsing this forum: Google Adsense [Bot] and 47 guests
