JD 2010 hydraulic line
I have a old 2010 crawler. The SN is worn off so not sure on the year. I think it's a 1963. The main hydraulic line from the motor on the right side to the back got a leak. A friend wanted to help and it was difficult to take off, so he cut it into several small pieces. I took it to get a hose made, but after paying for a new custom hose it will not fit because of the bigger diameter and the tight spaces. Does anyone know what the name of this line is or a part number? Can I get a replacement factory line? Are the tractor lines the same as the crawler lines?
1963 2010C loader
- 2010Crawler
- 420 crawler
- Contact:
Hyd. Line 2010
If it helps you, here you can search for the part number.
Simply enter 2010, and then select the crawler.
http://jdpc.deere.com/jdpc/servlet/com. ... ng_code=29
Re: Hyd. Line 2010
Awesome link, I am sorting through the manuals now.2010Crawler wrote:Hi,
I believe this is the transmission line. At idle it would be a minimal leak, but when in gear it squirted out. That part is AT16153.
Can anyone provide a link where I might be able to order one?
Found one for $180. That's pretty crazy though.
http://www.newoldstock.parts/john-deere ... t16153.htm
1963 2010C loader
You have to determine if it is high or low pressure. If it is a high pressure line, it will blow up copper line. Check and see if you have anyone in the area that makes steel line. We have one here called Tubes N Hoses that custom make steel line of all size and configuration.
1/2" type L soft/roll copper is good to 578PSI at 200ºF and 5/8 is good to 508 PSI at 200ºF......max pressure on 2010 trans is 110 PSI.... I be-live that the AT16153 is one of the ones i have made (years ago) out of copper .... JUST make sure that you use TYPE L soft .... TYPE K would be better (lots o luck finding any of that)
- gregjo1948
Then I wouldn't worry about it for a trans line, easy fix, just plug the end of the tubing as you push it through to keep dirt out.
Here's a link where it shipped from if anyone needs vintage parts they seem to have quite a few.
http://www.vpartsinc.com/
1963 2010C loader
Users browsing this forum: Google Adsense [Bot] and 249 guests
