Lifting a crawler.
woodsnwater
- 40C crawler
Lifting a crawler.
Can the lower final drive covers on a 420 support the weight of the machine?
- Paul Buhler
Yes.
When I have to work on my tracks, I back over a long 4x4 (or two small firewood logs), to get the pans up higher in the air. Then I block under them - snug. I then put a block of firewood or 8x8 under my blade to lift the front end of the machine and the tracks off the ground. Now the 4x4 can be removed, or not. I then use safety jack stands on 2x12 pads under the front cross member, and lower the machine onto them. I've found this to be a secure way to have the machine high enough in the air so that the machine can be run and the tracks spun. Handy for many tasks. Paul
woodsnwater
- 40C crawler
- Paul Buhler
Users browsing this forum: No registered users and 69 guests
