450b dozer steering clutches
Jimmy450b
Post by Jimmy450b » Tue Nov 10, 2015 6:05 pm
I'm installing new steering clutches in my 450b. I had to buy 2 new drums and new metal and metallic discs. When I installed the new discs they stick up above the drum but level with the hub. Is this normal? The count is right, 9 metallic and 8 steel. I checked the thickness, the steel are 10mm and the metallics are 20mm. ? [/img] Tried to load a picture.[/img]https://www.facebook.com/media/set/?set ... b520f9dcc2
Post by Lavoy » Tue Nov 10, 2015 7:57 pm
Your measurements seem off, what is thickness in SAE decimal?
Jimmy450b
Post by Jimmy450b » Tue Nov 10, 2015 10:11 pm
Lavoy wrote:Your measurements seem off, what is thickness in SAE decimal?
The steel discs are .097
Post by Lavoy » Tue Nov 10, 2015 11:20 pm
New spec is .105, so that is not the issue. Bolt the pressure plate on and see if the fingers adjust.
