jd 40c
ratskinner
jd 40c
Post by ratskinner » Tue Nov 03, 2015 7:42 pm
is the steering clutchs wet or dry?
will the motor from a 40c go into a 420c?
Post by Stan Disbrow » Tue Nov 03, 2015 9:06 pm
Steering clutches are dry.
40 motor is a little lower HP, but they fit a 420. Main external difference is a 40 has no water pump (thermosiphon) and the 420 does. Meaning a 40 motor might overheat in a 420 when the original engine did not. The radiator has to be pretty much perfect in a thermosiphon.
Post by Lavoy » Wed Nov 04, 2015 8:58 am
You will also have to change to 40 radiator, fan shroud, fan mount, in addition to changing out the throttle rod support. And, you will be sadly disappointed in the HP difference.
