OK still working on 440. As I was rebuilding the right steering clutch I noticed that the front cross member bolts appear to be loose. Is this a common thing? The other side seems like it has shims between the track system and mounting bracket.
I climbed under and tried a wrench. No worky. Should I try heating to remove? Should this have shims?
Many Thanks, Jaybird
440 stuck bolts
Fairly common, pain to fix, but they should not be loose.
- mapaduke@yahoo.com
Users browsing this forum: Google Adsense [Bot] and 275 guests
