cdv
cdv
new to the forum just got a JD440icd loader,,$2500,,undercarriage is very good cond, and Gm diesel runs good,,here s some ???? I have its a 5sp trans,,what is the small lever on top of trans by the shifter do,,why is it a 5 sp not 4sp trans,, and it will not start uless I give it a shot of either then runs great,,it has bin sitting inside not running for 5years thanks cdv
michaelkittrell
- 40C crawler
- GaCatskinner
- 420 crawler
- mapaduke@yahoo.com
- GaCatskinner
- 420 crawler
- GaCatskinner
- 420 crawler
Almost no original Detroit 53 series running S series pistons will start much below 70 degrees without a whiff of ether. An ether injector was a factory option, seen them on the 435 wheel tractors years ago.
5 speed was an option, PTO was an option.
Remember to run only Delo 100 or equivalent low ash oil in a two stroke Detroit.
