is it fairly straight foward to install a 4n1 bucket on this machine, has a ripper on it now if that matters at all.
all I would be getting would be the bucket and cylinders itself, no control valve or piping.
4 n 1 bucket for 1010 loader
As long as you have an aux valve to run it, should not be a big deal.
The 820/810 loader used on the 2010/1010 used a diverted valve for the ripper/41n1 in the rear of the valve box (see pic #1 here http://www.jdcrawlers.com/messageboard/ ... php?t=7806 ) to switch the second valve from ripper to 4in1 I believe this is the exact valve that was used should be 2 mounting holes in the back panel of the valve box where it bolts in http://www.ebay.com/itm/262059860550?ss ... 1436.l2661 Just different lever and end of spool is threaded on my ( I would have to look at my loader which is on a job right now)
Users browsing this forum: No registered users and 317 guests
