gearmatic 8a part
gearmatic 8a part
Hello all, I am looking for a replacement brake adjusting nut for a 8a gearmatic winch, it is located on the bottom outside of the clutch/brake side of the winch. It is item number 81 in the manual, part number A1103. I cannot find one for sale as a aftermarket part, can anyone help out?
Howard Yoder
- Paul Buhler
Tom:
On my winch it appears that this adjuster has been replaced with a piece of properly sized threaded water pipe (nipple) that has a doubled washer welded inside as a "bottom" for the shaft to rest upon. There are a couple of slots cut into the bottom so that a lever can be inserted to turn it up or down as needed. Not fancy, but it works. Pop Pop's offer sounds really good. Good luck Paul
pauls description is pretty accurate as that is what mine appears to be also.
i tried to measure it but is in a pretty tight spot.
the winch is on my bench and i cant roll it over without lifting it and my engine hoist is on the other side of the shop right now.
but i looked at it 3 times already,,, hope your a patient man.
i can probably get some measurements soon.
I resembles a pipe nipple, but isn't. It is standard NF thread, counterbored for the spring, and a slot milled in the bottom like a screwdriver slot. I had some made a long time ago, let me see if I have any left.
Sounds good lavoy, let me know!Lavoy wrote:I resembles a pipe nipple, but isn't. It is standard NF thread, counterbored for the spring, and a slot milled in the bottom like a screwdriver slot. I had some made a long time ago, let me see if I have any left.
Send me an e-mail so I don't forget. If I don't have any new ones left, I need to get another batch made up, will just need to find my pattern. Might take a little longer if you can wait.
